Introducción
This guide provides instructions on how to remove and replace the thumb scanner for the HP EliteBook x360 1030 G3.
The thumb scanner allows you to lock and unlock your computer using your thumb print. A failing thumb scanner simply does not read your thumb print, which may pose a problem in unlocking or locking your computer.
Before removing the thumb scanner, check to see if there happens to be any debris or contaminants on it. Cleaning the thumb scanner can be a simple solution to fixing the component. If cleaning it does not work, make sure to power off the laptop before attempting to replace.
Qué necesitas
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
Remove the six 1.95 mm JIS #000 screws that secure the metal frame of the touchpad.
Herramienta utilizada en este paso:Halberd Spudger$2.99
Use the Halberd Spudger to lift the ZIF connector tab and free the thumbprint ribbon cable.
