Saltar al contenido principal
HP EliteBook x360 1030 G3 Speakers Replacement
Qué necesitas
  1. HP EliteBook x360 1030 G3 Speakers Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Speakers Replacement: paso 2, imagen 1 de 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Speakers Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Speakers Replacement: paso 4, imagen 1 de 2 HP EliteBook x360 1030 G3 Speakers Replacement: paso 4, imagen 2 de 2
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Speakers Replacement: paso 5, imagen 1 de 1
    • Gently lift the battery out of its place.
  6. HP EliteBook x360 1030 G3 Speakers Replacement, Touchpad: paso 6, imagen 1 de 2 HP EliteBook x360 1030 G3 Speakers Replacement, Touchpad: paso 6, imagen 2 de 2
    • Remove the six 1.95 mm JIS #000 screws that secure the metal frame of the touchpad.
  7. HP EliteBook x360 1030 G3 Speakers Replacement: paso 7, imagen 1 de 3 HP EliteBook x360 1030 G3 Speakers Replacement: paso 7, imagen 2 de 3 HP EliteBook x360 1030 G3 Speakers Replacement: paso 7, imagen 3 de 3
    • Lift the small white ZIF connector from the front using a spudger tool or your finger.
    • Only lift the white hinge securing the Flexed Flat Cable making sure the unit stays secure to the board.
  8. HP EliteBook x360 1030 G3 Speakers Replacement: paso 8, imagen 1 de 1
    • Pull the yellow and orange striped ribbon away.
  9. HP EliteBook x360 1030 G3 Speakers Replacement: paso 9, imagen 1 de 1
    • Lift the touchpad up from the computer board by the metal frame.
  10. HP EliteBook x360 1030 G3 Speakers Replacement, Speakers: paso 10, imagen 1 de 3 HP EliteBook x360 1030 G3 Speakers Replacement, Speakers: paso 10, imagen 2 de 3 HP EliteBook x360 1030 G3 Speakers Replacement, Speakers: paso 10, imagen 3 de 3
    • Remove the two 3.52 mm JIS #000 screws from the left speaker.
    • The speakers are magnetic, so carefully remove from its magnetic place.
  11. HP EliteBook x360 1030 G3 Speakers Replacement: paso 11, imagen 1 de 3 HP EliteBook x360 1030 G3 Speakers Replacement: paso 11, imagen 2 de 3 HP EliteBook x360 1030 G3 Speakers Replacement: paso 11, imagen 3 de 3
    • Follow the red and black wire and you will see the two wire brackets.
    • Use the spudger to slide it and push the wire out of the brackets, then take it out.
  12. HP EliteBook x360 1030 G3 Speakers Replacement: paso 12, imagen 1 de 3 HP EliteBook x360 1030 G3 Speakers Replacement: paso 12, imagen 2 de 3 HP EliteBook x360 1030 G3 Speakers Replacement: paso 12, imagen 3 de 3
    • Remove the two 3.52 mm JIS #000 screws from the right speaker and carefully remove from its magnetic place.
    • Remove the black tape with your hand that is around wire.
  13. HP EliteBook x360 1030 G3 Speakers Replacement: paso 13, imagen 1 de 3 HP EliteBook x360 1030 G3 Speakers Replacement: paso 13, imagen 2 de 3 HP EliteBook x360 1030 G3 Speakers Replacement: paso 13, imagen 3 de 3
    • Remove the black tape from the mother board with your hand.
    • Unplug the green and white wire plug gently, and the red and black wire plug gently with your hand.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 438
