Saltar al contenido principal
HP EliteBook x360 1030 G3 Fan Replacement
Qué necesitas
  1. HP EliteBook x360 1030 G3 Fan Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Fan Replacement: paso 2, imagen 1 de 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Fan Replacement, Fan: paso 3, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws near the middle of the fan assembly.
    • Use the same screwdriver to remove the remaining five 3.9 mm screws.
  4. HP EliteBook x360 1030 G3 Fan Replacement: paso 4, imagen 1 de 3 HP EliteBook x360 1030 G3 Fan Replacement: paso 4, imagen 2 de 3 HP EliteBook x360 1030 G3 Fan Replacement: paso 4, imagen 3 de 3
    • Before pulling the fan out, identify the two wires that are connected to the fan and to the motherboard.
    • For each, use plastic opening tool to lift the black wire housing upward out of its port.
    • Be sure not to pull the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Fan Replacement: paso 5, imagen 1 de 2 HP EliteBook x360 1030 G3 Fan Replacement: paso 5, imagen 2 de 2
    • Slide the fan assembly toward you, and when the top edge of the fan is out of the vent grill, the fan is completely removed.
Conclusión
4 personas más completaron esta guía.
Pablo Arriola
Miembro Desde 04/22/19
504 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S2-G9, Maness Spring 2019 Miembro de Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 72
Todo El Tiempo: 4,406
