Introducción
If your computer will not connect with the internet, then you may need to replace the Wi-Fi card in your computer. This is a step-by-step guide on how to replace the Wi-Fi card. In order to replace it, the back cover of the laptop must be removed to expose the screw and cables which secure the Wi-Fi card and the card itself.
Please remember to power down your computer and unplug it to avoid any power surges or shorts. Failing to power down and disconnect the power cable may result in further harm to the laptop or even yourself, so precautions must be taken.
Qué necesitas
Paso 1 Lower Case
Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
Use a TR8 Torx screwdriver to remove:
Six 5.3 mm screws
Four 3.3 mm screws
