Introducción
This guide is intended to illustrate the process of removing a motherboard from an HP Elitebook Folio 1020 G1 so that it can be replaced.
Before taking any part of the computer apart, please remember to power down your computer and unplug the power cable from any power source. Failure to do so could harm yourself or the computer, so these precautions must be taken.
Qué necesitas
Paso 1 Lower Case
Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
Use a TR8 Torx screwdriver to remove:
Six 5.3 mm screws
Four 3.3 mm screws
Gently pull and free the battery's bundled cable connector that leads from the battery to the motherboard.
Attach terminals in reverse order of guide to new motherboard, reattach the battery and back panel.
