Saltar al contenido principal
HP EliteBook Folio 1020 G1 Motherboard Replacement
Qué necesitas
  1. Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
    HP EliteBook Folio 1020 G1 Motherboard Replacement, Lower Case: paso 1, imagen 1 de 1
    • Use a TR8 Torx screwdriver to remove:
    • Six 5.3 mm screws
    • Four 3.3 mm screws
  2. HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 2, imagen 1 de 1
    • Use a nylon spudger to gently pry the lower case up and off.
  3. HP EliteBook Folio 1020 G1 Motherboard Replacement, Battery: paso 3, imagen 1 de 2 HP EliteBook Folio 1020 G1 Motherboard Replacement, Battery: paso 3, imagen 2 de 2
    • Gently pull and free the battery's bundled cable connector that leads from the battery to the motherboard.
  4. HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #1 screwdriver to unscrew and remove the six 4 mm screws that secure the battery.
  5. HP EliteBook Folio 1020 G1 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 HP EliteBook Folio 1020 G1 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Remove:
    • Eight 4.6 mm screws shown in the circles using Phillips #0.
  6. HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 6, imagen 1 de 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 6, imagen 2 de 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 6, imagen 3 de 3
    • Disconnect the keyboard connections from the motherboard.
    • Disconnect by lifting the underside of the white tabs with a spudger.
  7. HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 7, imagen 1 de 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 7, imagen 2 de 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 7, imagen 3 de 3
    • Disconnect circled terminals. Disconnect by lifting the underside of white tabs with spudger.
  8. HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 8, imagen 1 de 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 8, imagen 2 de 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the circled tabs by pulling on the white support edges backward with a pair of tweezers.
  9. HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 9, imagen 1 de 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 9, imagen 2 de 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 9, imagen 3 de 3
    • Gently pull on the black pull tab on the top of the connector.
    • For the wires going to the Wi-fi card, remove both wires going to the top of the card using the tweezers.
  10. HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 10, imagen 1 de 2 HP EliteBook Folio 1020 G1 Motherboard Replacement: paso 10, imagen 2 de 2
    • Lift the now disconnected motherboard from the side shown in image 1. This side must be lifted to not damage the ports. The disconnected motherboard (aside from port removed in step 12) is shown in image 2.
Conclusión
Attach terminals in reverse order of guide to new motherboard, reattach the battery and back panel.
Zachary Sinnott
Miembro Desde 03/28/23
133 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-1, Harley Spring 2023 Miembro de IUPUI, Team 2-1, Harley Spring 2023
IUPUI-HARLEY-S23S2G1
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 189
