Saltar al contenido principal
HP EliteBook 8560w Back Panel Replacement
Qué necesitas
  1. HP EliteBook 8560w Back Panel Replacement, Battery: paso 1, imagen 1 de 2 HP EliteBook 8560w Back Panel Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Back Panel Replacement: paso 2, imagen 1 de 1
    • Pull the battery out.
  3. HP EliteBook 8560w Back Panel Replacement, Back Panel: paso 3, imagen 1 de 2 HP EliteBook 8560w Back Panel Replacement, Back Panel: paso 3, imagen 2 de 2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Back Panel Replacement: paso 4, imagen 1 de 1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 31
Todo El Tiempo: 1,438
