Saltar al contenido principal
HP EliteBook 840 G7 Heatsink Replacement
Qué necesitas
  1. HP EliteBook 840 G7 Heatsink Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Heatsink Replacement: paso 2, imagen 1 de 1
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Heatsink Replacement: paso 3, imagen 1 de 1
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Heatsink Replacement: paso 4, imagen 1 de 3 HP EliteBook 840 G7 Heatsink Replacement: paso 4, imagen 2 de 3 HP EliteBook 840 G7 Heatsink Replacement: paso 4, imagen 3 de 3
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Heatsink Replacement: paso 5, imagen 1 de 3 HP EliteBook 840 G7 Heatsink Replacement: paso 5, imagen 2 de 3 HP EliteBook 840 G7 Heatsink Replacement: paso 5, imagen 3 de 3
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Heatsink Replacement, Heatsink: paso 6, imagen 1 de 2 HP EliteBook 840 G7 Heatsink Replacement, Heatsink: paso 6, imagen 2 de 2
    • Separate cables from heatsink and fan.
    • Unplug the fan power cable.
  7. HP EliteBook 840 G7 Heatsink Replacement: paso 7, imagen 1 de 3 HP EliteBook 840 G7 Heatsink Replacement: paso 7, imagen 2 de 3 HP EliteBook 840 G7 Heatsink Replacement: paso 7, imagen 3 de 3
    • Use a Phillips # 1 screwdriver to remove the three 5mm screws from the fan housing.
    • Remove the fan from computer.
  8. HP EliteBook 840 G7 Heatsink Replacement: paso 8, imagen 1 de 3 HP EliteBook 840 G7 Heatsink Replacement: paso 8, imagen 2 de 3 HP EliteBook 840 G7 Heatsink Replacement: paso 8, imagen 3 de 3
    • Use a Phillips # 1 screwdriver to remove the four 4mm screws from the heatsink.
    • Remove the heat sink from computer.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 37
Todo El Tiempo: 587
