Saltar al contenido principal
HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Battery: paso 1, imagen 1 de 2 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Use a JIS #0 screwdriver to unscrew the three 6.73 mm case retention screws.
    • Use a JIS #0 screwdriver to unscrew and remove the two 8.76 mm screws.
  2. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 2, imagen 1 de 2 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Halberd Spudger
    $2.99
    • Use the Halberd Spudger to remove the cable running along the bottom of the battery
  3. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 3, imagen 1 de 2 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 3, imagen 2 de 2
    • Disconnect the cable connected the battery to the motherboard
  4. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 4, imagen 1 de 2 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 4, imagen 2 de 2
    • Use a JIS #0 screwdriver to unscrew the four 7 mm screws that secure the battery.
  5. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 5, imagen 1 de 1
    • Slide the battery out of the clips to remove it from the laptop.
  6. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Heat Sink and Fan: paso 6, imagen 1 de 2 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Heat Sink and Fan: paso 6, imagen 2 de 2
    • Unplug the fan cable from the motherboard.
  7. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 7, imagen 1 de 2 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 7, imagen 2 de 2
    • Use the JIS #0 screwdriver to remove the three 5.33 mm screws that secure the fan.
  8. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 8, imagen 1 de 2 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 8, imagen 2 de 2
    • Use a JIS #0 screwdriver to remove the four 4.06 mm screws from the heat sink.
  9. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 9, imagen 1 de 1
    • Lift the fan free.
  10. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: paso 10, imagen 1 de 1
    • Lift the heat sink free.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 40
Todo El Tiempo: 1,047
