Saltar al contenido principal
HP EliteBook 745 G6 RAM Replacement
Qué necesitas
  1. HP EliteBook 745 G6 RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Type CMD in the Start Menu and open Command Prompt.
    • Type the following command to view memory details and press Enter.
    • wmic memorychip get devicelocator, manufacturer, partnumber, serialnumber, capacity, speed, memorytype, formfactor.
  2. HP EliteBook 745 G6 RAM Replacement: paso 2, imagen 1 de 1
    • Power off the Notebook.
    • Select the Start button.
    • Select the Power button.
    • Select Shut down.
    • Disconnect the power adapter.
  3. HP EliteBook 745 G6 RAM Replacement: paso 3, imagen 1 de 2 HP EliteBook 745 G6 RAM Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    • Turn the notebook upside down on a flat surface.
    • Loosen the six captive screws and the two inset captive screws counter-clockwise with the Phillips #00 screwdriver.
    • Pry the bottom cover with plastic card or spudger at the bottom right corner.
    • Lift the bottom cover off with plastic card.
  4. HP EliteBook 745 G6 RAM Replacement: paso 4, imagen 1 de 2 HP EliteBook 745 G6 RAM Replacement: paso 4, imagen 2 de 2
    Anti-Static Wrist Strap
    $7.95
  5. HP EliteBook 745 G6 RAM Replacement: paso 5, imagen 1 de 2 HP EliteBook 745 G6 RAM Replacement: paso 5, imagen 2 de 2
    • Be sure to ground yourself by wearing anti-static wrist strap.
    • Do not remove memory shielding from the system board when replacing memory.
    • The socket labeled 2 houses the expansion memory module and the socket labeled 1 houses the primary memory module.
    • Spread the retaining tabs on each side of the memory module slot to release the memory module.
    • Pull the memory module away from the slot at an angle.
  6. HP EliteBook 745 G6 RAM Replacement: paso 6, imagen 1 de 2 HP EliteBook 745 G6 RAM Replacement: paso 6, imagen 2 de 2
    • Insert the memory module into the slot at an angle.
    • Push down the center of memory module until the retaining tabs lock the RAM stick.
  7. HP EliteBook 745 G6 RAM Replacement: paso 7, imagen 1 de 1
    • Insert the battery cable into the system board.
  8. HP EliteBook 745 G6 RAM Replacement: paso 8, imagen 1 de 2 HP EliteBook 745 G6 RAM Replacement: paso 8, imagen 2 de 2
    • Push down the bottom cover at the four corner and center.
    • Tighten the six captive screws and the two inset captive screws clockwise with Phillips #00 screwdriver.
  9. HP EliteBook 745 G6 RAM Replacement: paso 9, imagen 1 de 1
    • Push the power button.
  10. HP EliteBook 745 G6 RAM Replacement: paso 10, imagen 1 de 2 HP EliteBook 745 G6 RAM Replacement: paso 10, imagen 2 de 2
    • Right-click on the taskbar.
    • Select the “Task Manager”.
    • Select the "Performance".
Conclusión
Una persona más ha completado esta guía.
Mengqi Shi
Miembro Desde 05/05/21
208 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 23
Ultimos 30 días: 79
Todo El Tiempo: 2,767
