Saltar al contenido principal
HP EliteBook 745 G2 RAM Chip Replacement
Qué necesitas
  1. HP EliteBook 745 G2 RAM Chip Replacement, Battery: paso 1, imagen 1 de 1
    • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
  2. HP EliteBook 745 G2 RAM Chip Replacement: paso 2, imagen 1 de 2 HP EliteBook 745 G2 RAM Chip Replacement: paso 2, imagen 2 de 2
    • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
  3. HP EliteBook 745 G2 RAM Chip Replacement: paso 3, imagen 1 de 2 HP EliteBook 745 G2 RAM Chip Replacement: paso 3, imagen 2 de 2
    • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
  4. HP EliteBook 745 G2 RAM Chip Replacement, RAM Chip: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
  5. HP EliteBook 745 G2 RAM Chip Replacement: paso 5, imagen 1 de 1
    • Using the spudger, gently press down on the tabs holding the chip to release it. Repeat this step for the other chip.
  6. HP EliteBook 745 G2 RAM Chip Replacement: paso 6, imagen 1 de 1
    • Grab the chip and lift it away from the laptop at a 45 degree angle.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 492
