Saltar al contenido principal
HP EliteBook 1050 G1 Keyboard Panel Replacement
Qué necesitas
  1. HP EliteBook 1050 G1 Keyboard Panel Replacement, Motherboard: paso 1, imagen 1 de 2 HP EliteBook 1050 G1 Keyboard Panel Replacement, Motherboard: paso 1, imagen 2 de 2
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Pry open the backplate with a Jimmy.
  2. HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 2, imagen 1 de 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 2, imagen 2 de 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 2, imagen 3 de 3
    • Remove the two 1.9mm screws from the SSDs with a Phillips #0 driver.
    • Disconnect the two PCIe SSDs by sliding them out of each port.
  3. HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 3, imagen 1 de 2 HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 3, imagen 2 de 2
    • Pull the clips on either side of the RAM chip away from each other using your fingers.
    • As you pry apart the clips, the RAM should pop up to rest at an angle to the motherboard.
    • Slide the RAM chips out of their respective slots.
  4. HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 4, imagen 1 de 2 HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 4, imagen 2 de 2
    • Remove eight 4.5 mm screws from the battery with a Phillips #1 screwdriver.
    • Disconnect the white tipped battery cable from the motherboard.
  5. HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 5, imagen 1 de 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 5, imagen 2 de 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 5, imagen 3 de 3
    • Remove the six 4.5mm screws from the fan assembly using a Phillips #00 screwdriver.
    • Unscrew four 3.6mm screws from the heatsink assembly with a Phillips #00 screwdriver.
    • These "captive" screws are connected to the heatsink and will not detach from it.
    • Remove the fan assembly.
  6. HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 6, imagen 1 de 1
    • Unplug the seven ZIF connecters from the motherboard by flipping up the black switches with a spudger and pulling out the cables.
  7. HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 7, imagen 1 de 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 7, imagen 2 de 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 7, imagen 3 de 3
    • Remove two 1.9mm screws from the display cable bracket using a Phillips #00 driver.
    • Remove the two connectors on the right side gently.
    • Remove the connector on right side of motherboard.
    • Remove the three 4.5mm screws using a Phillips #00 driver and remove the bracket.
    • Remove the two coaxial cables.
  8. HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 8, imagen 1 de 2 HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 8, imagen 2 de 2
    • Remove the two 3mm screws using a Phillips #00 driver.
    • Remove the motherboard by lifting it up and out of the case.
  9. HP EliteBook 1050 G1 Keyboard Panel Replacement, Keyboard Panel: paso 9, imagen 1 de 3 HP EliteBook 1050 G1 Keyboard Panel Replacement, Keyboard Panel: paso 9, imagen 2 de 3 HP EliteBook 1050 G1 Keyboard Panel Replacement, Keyboard Panel: paso 9, imagen 3 de 3
    • Peel back the black cover on the keyboard.
  10. HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 10, imagen 1 de 1
    • Remove all 52 screws from the keyboard panel using a Phillips #000 screwdriver.
  11. HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 11, imagen 1 de 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 11, imagen 2 de 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: paso 11, imagen 3 de 3
    • Remove the keyboard panel from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 44
Todo El Tiempo: 757
