Saltar al contenido principal
HP EliteBook 1040 G4 Trackpad Replacement
Qué necesitas
  1. HP EliteBook 1040 G4 Trackpad Replacement, Back Cover: paso 1, imagen 1 de 1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Trackpad Replacement: paso 2, imagen 1 de 2 HP EliteBook 1040 G4 Trackpad Replacement: paso 2, imagen 2 de 2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Trackpad Replacement, Battery: paso 3, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Trackpad Replacement: paso 4, imagen 1 de 2 HP EliteBook 1040 G4 Trackpad Replacement: paso 4, imagen 2 de 2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Trackpad Replacement: paso 5, imagen 1 de 2 HP EliteBook 1040 G4 Trackpad Replacement: paso 5, imagen 2 de 2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Trackpad Replacement, Trackpad: paso 6, imagen 1 de 1
    • Peel back the foam cover to reveal the underside of the trackpad.
  7. HP EliteBook 1040 G4 Trackpad Replacement: paso 7, imagen 1 de 1
    • Carefully disconnect the white ribbon cable attached to the underside of the trackpad.
  8. HP EliteBook 1040 G4 Trackpad Replacement: paso 8, imagen 1 de 1
    • Carefully disconnect the black ribbon cable attached to the chassis.
  9. HP EliteBook 1040 G4 Trackpad Replacement: paso 9, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws securing the trackpad.
  10. HP EliteBook 1040 G4 Trackpad Replacement: paso 10, imagen 1 de 1
    • Lift and remove the trackpad from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 431
