Saltar al contenido principal
HP EliteBook 1040 G4 Speakers Replacement
Qué necesitas
  1. HP EliteBook 1040 G4 Speakers Replacement, Back Cover: paso 1, imagen 1 de 1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Speakers Replacement: paso 2, imagen 1 de 2 HP EliteBook 1040 G4 Speakers Replacement: paso 2, imagen 2 de 2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Speakers Replacement, Battery: paso 3, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Speakers Replacement: paso 4, imagen 1 de 2 HP EliteBook 1040 G4 Speakers Replacement: paso 4, imagen 2 de 2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Speakers Replacement: paso 5, imagen 1 de 2 HP EliteBook 1040 G4 Speakers Replacement: paso 5, imagen 2 de 2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Speakers Replacement, Speakers: paso 6, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove the four black 6 mm screws securing the speakers to the device.
  7. HP EliteBook 1040 G4 Speakers Replacement: paso 7, imagen 1 de 1
    • Disconnect the pin connector from the right side of the speaker assembly.
  8. HP EliteBook 1040 G4 Speakers Replacement: paso 8, imagen 1 de 1
    • Carefully remove the red and black wires from the black clips in between the two speakers.
  9. HP EliteBook 1040 G4 Speakers Replacement: paso 9, imagen 1 de 1
    • Remove the speakers from the device.
Conclusión
Equipo
Clemson, Team 4-1, Hunter Fall 2021 Miembro de Clemson, Team 4-1, Hunter Fall 2021
CLEM-HUNTER-F21S4G1
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 634
