Saltar al contenido principal
HP Elite x2 G1 1012 Motherboard Replacement Guide
Qué necesitas
  1. HP Elite x2 G1 1012 Motherboard Replacement Guide, Motherboard: paso 1, imagen 1 de 2 HP Elite x2 G1 1012 Motherboard Replacement Guide, Motherboard: paso 1, imagen 2 de 2
    • Detach the keyboard from the screen.
  2. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 2, imagen 1 de 1
    • While the screen is facing down, remove six 3.0 mm Torx T5 screws under the stand.
    • The screws were not available when we received our device.
  3. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 3, imagen 1 de 3 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 3, imagen 2 de 3 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 3, imagen 3 de 3
    • Use a suction cup to remove the screen panel.
  4. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 4, imagen 1 de 3 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 4, imagen 2 de 3 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 4, imagen 3 de 3
    • Detach flex cable from motherboard using tweezers.
  5. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 5, imagen 1 de 1
    • Unplug the battery wire attached to the motherboard using tweezers.
  6. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 6, imagen 1 de 3 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 6, imagen 2 de 3 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 6, imagen 3 de 3
    • Remove ten 2.7mm screws using the Phillips #0 screwdriver.
  7. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 7, imagen 1 de 2 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 7, imagen 2 de 2
    • Unplug the speaker wire attached to the motherboard.
  8. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 8, imagen 1 de 2 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 8, imagen 2 de 2
    • Detach the left speaker.
  9. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 9, imagen 1 de 2 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 9, imagen 2 de 2
    • Detach the two stickers highlighted from the right speaker.
  10. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 10, imagen 1 de 1
    • Detach the right speaker cables from the motherboard using tweezers.
  11. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 11, imagen 1 de 2 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 11, imagen 2 de 2
    • Detach the right speaker.
  12. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 12, imagen 1 de 1
    • Detach the WWAN card from the motherboard by pulling it to the left using tweezers.
  13. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 13, imagen 1 de 1
    • Detach the SSD from motherboard by pulling it to the left using tweezers.
  14. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 14, imagen 1 de 1
    • Use the plastic opening tool to loosen the motherboard.
  15. HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 15, imagen 1 de 3 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 15, imagen 2 de 3 HP Elite x2 G1 1012 Motherboard Replacement Guide: paso 15, imagen 3 de 3
    • Detach the motherboard from the casing.
    • Apply pulling force to the left to pull out the ports from the casing safely.
Conclusión
3 personas más completaron esta guía.
Hanif Norhisham
Miembro Desde 05/22/19
571 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G5, Harley Summer 2019 Miembro de IUPUI, Team S1-G5, Harley Summer 2019
IUPUI-HARLEY-SU19S1G5
4 Miembros
2 Guías creadas
Un comentario
¿basta con esto para cambiar el cable LCD?
Is this enough to replace the LCD wire?
Pablo Sánchez-Simón - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 32
Todo El Tiempo: 3,187
