Saltar al contenido principal
HP Elite x2 1012 G2 Cooling Fan Replacement
Qué necesitas
  1. HP Elite x2 1012 G2 Cooling Fan Replacement, Screen: paso 1, imagen 1 de 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 2, imagen 1 de 3 HP Elite x2 1012 G2 Cooling Fan Replacement: paso 2, imagen 2 de 3 HP Elite x2 1012 G2 Cooling Fan Replacement: paso 2, imagen 3 de 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 3, imagen 1 de 2 HP Elite x2 1012 G2 Cooling Fan Replacement: paso 3, imagen 2 de 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 4, imagen 1 de 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 5, imagen 1 de 3 HP Elite x2 1012 G2 Cooling Fan Replacement: paso 5, imagen 2 de 3 HP Elite x2 1012 G2 Cooling Fan Replacement: paso 5, imagen 3 de 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 6, imagen 1 de 2 HP Elite x2 1012 G2 Cooling Fan Replacement: paso 6, imagen 2 de 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Cooling Fan Replacement, Battery: paso 7, imagen 1 de 1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 8, imagen 1 de 2 HP Elite x2 1012 G2 Cooling Fan Replacement: paso 8, imagen 2 de 2
    • Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
  9. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 9, imagen 1 de 2 HP Elite x2 1012 G2 Cooling Fan Replacement: paso 9, imagen 2 de 2
    • Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
  10. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 10, imagen 1 de 1
    • Lift the battery out of the device.
  11. HP Elite x2 1012 G2 Cooling Fan Replacement, Cooling Fan: paso 11, imagen 1 de 1
    • Use the spudger tools to lift the copper tape and expose the screws.
  12. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 12, imagen 1 de 2 HP Elite x2 1012 G2 Cooling Fan Replacement: paso 12, imagen 2 de 2
    • Use Phillips #00 screwdriver to remove seven 3 mm screws.
  13. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 13, imagen 1 de 1
    • Lift the heatsink off the motherboard.
  14. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 14, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the final two 3 mm screws that secure the fan.
  15. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 15, imagen 1 de 1
    • Use a spudger to lift the fan from the main unit.
  16. HP Elite x2 1012 G2 Cooling Fan Replacement: paso 16, imagen 1 de 1
    • Use a spudger to lift the connection for the fan and disconnect the plug from the motherboard.
Conclusión
2 personas más completaron esta guía.
WesleyEagleson
Miembro Desde 04/06/19
431 Reputación
3 Guías creadas
Equipo
IUPUI, Team S13-G13, Wilson Spring 2019 Miembro de IUPUI, Team S13-G13, Wilson Spring 2019
IUPUI-WILSON-S19S13G13
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 43
Todo El Tiempo: 2,505
