Saltar al contenido principal
HP Elite X2 G4 Display Assembly Replacement
Qué necesitas
  1. HP Elite X2 G4 Display Assembly Replacement, Display Assembly: paso 1, imagen 1 de 1
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite X2 G4 Display Assembly Replacement: paso 2, imagen 1 de 1
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite X2 G4 Display Assembly Replacement: paso 3, imagen 1 de 1
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite X2 G4 Display Assembly Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite X2 G4 Display Assembly Replacement: paso 5, imagen 1 de 1
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
Conclusión
Una persona más ha completado esta guía.
Goncalo Felix
Miembro Desde 10/25/22
325 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 Miembro de UMass Dartmouth, Team 4-4, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G4
5 Miembros
3 Guías creadas
Un comentario
Boa tarde Gonçalo.
Sabe dizer-me onde posso comprar um ecrã original para o meu HP Elite X2 G4?
Obrigado
Pedro Santos
Pedro_Neno - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 43
Todo El Tiempo: 589
