Introducción
If your device cannot access or recognize your Wi-Fi networks, the wireless card may be faulty. This guide will show you how to replace the wireless card in your device.
Qué necesitas
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
Un comentario
Just to note, this is the WWAN (cellular/LTE) card, not the WLAN card (WiFi). The WLAN card is soldered down and not removable.
