Introducción
If the battery on your laptop no longer holds charge or otherwise needs replacement, use this guide to remove and replace it.
If your battery appears to be swollen, please see iFixits related Wiki.
Qué necesitas
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
Una persona más ha completado esta guía.
