Saltar al contenido principal
HP ENVY Rove 20-k014us Battery Replacement
Qué necesitas
  1. HP ENVY Rove 20-k014us Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Working on your device while it’s turned on is potentially dangerous and can result in electrical shock. Please make sure your device is completely turned off before you begin disassembling it.
    • Flip the device over so the screen is face down.
    • Make sure the stand is flipped down for the easiest way to work with the device.
    • Make sure that you put the screen on a clean surface to avoid scratching it.
  2. HP ENVY Rove 20-k014us Battery Replacement: paso 2, imagen 1 de 1
    • Remove the SD card in the bottom of the computer by pressing the SD card in, and it will pop out.
    • Pull out the SD card completely and set aside.
    • If you have never put in an SD card into this slot, a dummy one will be there in the slot.
  3. HP ENVY Rove 20-k014us Battery Replacement: paso 3, imagen 1 de 2 HP ENVY Rove 20-k014us Battery Replacement: paso 3, imagen 2 de 2
    • Remove the two rubber screw covers on the bottom of the plastic cover using the plastic opening tool.
    • Unscrew the two 6.35 mm PH#1 screws that were underneath the rubber covers.
    • The screws cannot be removed, they just unscrew from the interior components of the computer.
  4. HP ENVY Rove 20-k014us Battery Replacement: paso 4, imagen 1 de 2 HP ENVY Rove 20-k014us Battery Replacement: paso 4, imagen 2 de 2
    • Use the plastic opening tool along the outer rim of the bottom portion of the back panel.
    • Take off this portion.
    • Removing the cover for the first time requires a bit of force. Use the plastic opening tool to get as much separation as possible before you pull off the cover to help prevent it from cracking.
  5. HP ENVY Rove 20-k014us Battery Replacement: paso 5, imagen 1 de 2 HP ENVY Rove 20-k014us Battery Replacement: paso 5, imagen 2 de 2
    • Remove three 6.35 mm screw from the back panel using a PH#2 or J1 screw driver.
    • Unscrew the two 6.35 mm PH#2 screws. They aren't able to be completely removed and will just be loosened similar to step 3.
  6. HP ENVY Rove 20-k014us Battery Replacement: paso 6, imagen 1 de 2 HP ENVY Rove 20-k014us Battery Replacement: paso 6, imagen 2 de 2
    • Release the stand by pressing the large button on the left so that it is easier to take the back case off.
  7. HP ENVY Rove 20-k014us Battery Replacement: paso 7, imagen 1 de 3 HP ENVY Rove 20-k014us Battery Replacement: paso 7, imagen 2 de 3 HP ENVY Rove 20-k014us Battery Replacement: paso 7, imagen 3 de 3
    • Use the plastic opening tool to separate the silver back cover from the screen body.
    • As shown in picture two, use the tool around the stand as well to avoid cracking the cover.
    • As with the bottom cover, removing the top cover requires some force. Using the plastic opening tool to get as much separation as possible will make your job easier in the long run.
  8. HP ENVY Rove 20-k014us Battery Replacement: paso 8, imagen 1 de 1
    • Slowly apply pressure to the outsides of the cover until it pops out of place.
    • Carefully lift the cover away from the computer and untangle it from the stand.
    • When putting the back cover back on, make sure you put the bottom of the cover on first so that the plastic cover sits tightly underneath the bottom of the stand case. Then make sure all the plastic tabs are fully pushed in.
    • Make sure that the power button is aligned when you put the back cover on.
  9. HP ENVY Rove 20-k014us Battery Replacement: paso 9, imagen 1 de 2 HP ENVY Rove 20-k014us Battery Replacement: paso 9, imagen 2 de 2
    • Before working on any of the internal components of the computer, make sure the battery is disconnected so there's no power running through the device.
    • Disconnect the battery by using a plastic opening tool and taking the cable connection out.
  10. HP ENVY Rove 20-k014us Battery Replacement, Hard Drive and Case: paso 10, imagen 1 de 1
    • Remove the two black 6.35mm PH #0 screws with a screwdriver from the top of the hard drive.
    • Remove the two silver 6.35mm PH#0 screws from the bottom of the hard drive.
  11. HP ENVY Rove 20-k014us Battery Replacement: paso 11, imagen 1 de 1
    • Gently remove the hard drive from the computer.
    • Unplug the hard drive.
  12. HP ENVY Rove 20-k014us Battery Replacement, Stand Recess: paso 12, imagen 1 de 1
    • Release the stand by pushing the grey lever in towards the screen.
    • Doing this will allow you to access and remove the plastic casing (stand recess) around the stand itself in the next step.
  13. HP ENVY Rove 20-k014us Battery Replacement: paso 13, imagen 1 de 1
    • Remove the fourteen 6.35 mm PH#0 screws around the stand recess and metal cage.
  14. HP ENVY Rove 20-k014us Battery Replacement: paso 14, imagen 1 de 2 HP ENVY Rove 20-k014us Battery Replacement: paso 14, imagen 2 de 2
    • Gently remove wires from around the stand recess with the plastic opening tool.
  15. HP ENVY Rove 20-k014us Battery Replacement: paso 15, imagen 1 de 1
    • Remove the metal cage.
  16. HP ENVY Rove 20-k014us Battery Replacement: paso 16, imagen 1 de 2 HP ENVY Rove 20-k014us Battery Replacement: paso 16, imagen 2 de 2
    • Remove the stand recess by moving it towards yourself, rotating it about the hinge and then taking it out of the computer.
  17. HP ENVY Rove 20-k014us Battery Replacement, Battery: paso 17, imagen 1 de 1
    • Remove the four 6.35 mm PH#0 screws from around the battery using the J1 screwdriver.
  18. HP ENVY Rove 20-k014us Battery Replacement: paso 18, imagen 1 de 2 HP ENVY Rove 20-k014us Battery Replacement: paso 18, imagen 2 de 2
    • Disconnect the power button connector cable.
    • Disconnect the cable connection that's wrapped around the battery.
  19. HP ENVY Rove 20-k014us Battery Replacement: paso 19, imagen 1 de 3 HP ENVY Rove 20-k014us Battery Replacement: paso 19, imagen 2 de 3 HP ENVY Rove 20-k014us Battery Replacement: paso 19, imagen 3 de 3
    • Gently extricate the wires around the battery using a plastic opening tool.
  20. HP ENVY Rove 20-k014us Battery Replacement: paso 20, imagen 1 de 1
    • Gently remove the battery from the computer, making sure not to tug on any of the cables or wires during the removal.
Conclusión
9 personas más completaron esta guía.
Berit Bingham
Miembro Desde 10/06/15
1,464 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 4-4, Maness Fall 2015 Miembro de Cal Poly, Team 4-4, Maness Fall 2015
CPSU-MANESS-F15S4G4
4 Miembros
15 Guías creadas
Un comentario
Excellent Guide to use for this All in One, I enjoyed Finding and Using it
Louis R. Boucher - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 36
Todo El Tiempo: 4,343
