Introducción
Removing the battery from the device is tricky because of the amount of wires attached to it and surrounding it. We did our best to take pictures showing how the wires are arranged and the best method for untangling them however it really just takes some time and care. Start by unplugging all the wires you can and then try to untangle them from the battery for best results. Good luck!
Qué necesitas
Remove the two black 6.35mm PH #0 screws with a screwdriver from the top of the hard drive.
Remove the two silver 6.35mm PH#0 screws from the bottom of the hard drive.
Remove the four 6.35 mm PH#0 screws from around the battery using the J1 screwdriver.
9 personas más completaron esta guía.
Un comentario
Excellent Guide to use for this All in One, I enjoyed Finding and Using it
