Saltar al contenido principal
HP ENVY 5530 Power Supply Replacement
Qué necesitas
  1. HP ENVY 5530 Power Supply Replacement, AC Adaptor: paso 1, imagen 1 de 3 HP ENVY 5530 Power Supply Replacement, AC Adaptor: paso 1, imagen 2 de 3 HP ENVY 5530 Power Supply Replacement, AC Adaptor: paso 1, imagen 3 de 3
    • Open the the printer by lifting the top section. Make sure you're lifting from the lowest portion of the scanner section.
  2. HP ENVY 5530 Power Supply Replacement: paso 2, imagen 1 de 3 HP ENVY 5530 Power Supply Replacement: paso 2, imagen 2 de 3 HP ENVY 5530 Power Supply Replacement: paso 2, imagen 3 de 3
    • Locate 13mm TR10 Torx Security screw behind screen and remove using Torx screwdriver.
  3. HP ENVY 5530 Power Supply Replacement: paso 3, imagen 1 de 3 HP ENVY 5530 Power Supply Replacement: paso 3, imagen 2 de 3 HP ENVY 5530 Power Supply Replacement: paso 3, imagen 3 de 3
    • Remove case covering by lifting it up to reveal the power cord.
  4. HP ENVY 5530 Power Supply Replacement: paso 4, imagen 1 de 2 HP ENVY 5530 Power Supply Replacement: paso 4, imagen 2 de 2
    • Locate power cord.
    • Pull it out.
  5. HP ENVY 5530 Power Supply Replacement: paso 5, imagen 1 de 2 HP ENVY 5530 Power Supply Replacement: paso 5, imagen 2 de 2
    • Locate 13mm TR10 Torx Security screw behind screen and remove with screwdriver.
  6. HP ENVY 5530 Power Supply Replacement: paso 6, imagen 1 de 2 HP ENVY 5530 Power Supply Replacement: paso 6, imagen 2 de 2
    • Use a metal spudger around the edge to remove AC adapter cover.
  7. HP ENVY 5530 Power Supply Replacement: paso 7, imagen 1 de 1
    • Pull the AC adaptor up and out of its casing
  8. HP ENVY 5530 Power Supply Replacement: paso 8, imagen 1 de 3 HP ENVY 5530 Power Supply Replacement: paso 8, imagen 2 de 3 HP ENVY 5530 Power Supply Replacement: paso 8, imagen 3 de 3
    • Disconnect the wires from the AC adaptor.
    • Replace AC Adapter box. Reverse order of instructions for reassembly.
Conclusión
3 personas más completaron esta guía.
Justin
Miembro Desde 02/15/18
295 Reputación
1 Guía escrita
Equipo
USF-Leahy-S18S1G1 Miembro de USF-Leahy-S18S1G1
Community
3 Miembros
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 29
Todo El Tiempo: 1,622
