Saltar al contenido principal
HP ENVY 5530 Paper Tray Replacement
Qué necesitas
  1. HP ENVY 5530 Paper Tray Replacement, Paper Tray: paso 1, imagen 1 de 2 HP ENVY 5530 Paper Tray Replacement, Paper Tray: paso 1, imagen 2 de 2
    • Grab both sides of the printer and flip it away from you so the bottom is facing up.
  2. HP ENVY 5530 Paper Tray Replacement: paso 2, imagen 1 de 1
    • Locate the 13mm TR10 Torx screws on the left side of the paper tray.
  3. HP ENVY 5530 Paper Tray Replacement: paso 3, imagen 1 de 2 HP ENVY 5530 Paper Tray Replacement: paso 3, imagen 2 de 2
    • Unscrew and remove the 13mm TR10 Torx Security screw, starting with the farthest screw on the left
  4. HP ENVY 5530 Paper Tray Replacement: paso 4, imagen 1 de 2 HP ENVY 5530 Paper Tray Replacement: paso 4, imagen 2 de 2
    • Locate and remove middle 13mm TR10 Torx Security screw using a Torx screwdriver.
  5. HP ENVY 5530 Paper Tray Replacement: paso 5, imagen 1 de 2 HP ENVY 5530 Paper Tray Replacement: paso 5, imagen 2 de 2
    • Locate and remove the last 13mm TR10 Torx Security screw.
  6. HP ENVY 5530 Paper Tray Replacement: paso 6, imagen 1 de 2 HP ENVY 5530 Paper Tray Replacement: paso 6, imagen 2 de 2
    • Locate the side tab and lift up to remove.
  7. HP ENVY 5530 Paper Tray Replacement: paso 7, imagen 1 de 1
    • Locate the three 13mm TR10 Torx Security screws on the right side panel.
  8. HP ENVY 5530 Paper Tray Replacement: paso 8, imagen 1 de 2 HP ENVY 5530 Paper Tray Replacement: paso 8, imagen 2 de 2
    • Locate and remove the farthest 13mm TR10 Torx Security screw.
  9. HP ENVY 5530 Paper Tray Replacement: paso 9, imagen 1 de 2 HP ENVY 5530 Paper Tray Replacement: paso 9, imagen 2 de 2
    • Locate middle 13mm TR10 Torx Security screw and remove it.
  10. HP ENVY 5530 Paper Tray Replacement: paso 10, imagen 1 de 2 HP ENVY 5530 Paper Tray Replacement: paso 10, imagen 2 de 2
    • Locate last 13mm TR10 Torx Security screw and remove it.
  11. HP ENVY 5530 Paper Tray Replacement: paso 11, imagen 1 de 2 HP ENVY 5530 Paper Tray Replacement: paso 11, imagen 2 de 2
    • Locate tab on the right side panel and lift to remove it.
  12. HP ENVY 5530 Paper Tray Replacement: paso 12, imagen 1 de 1
    • The back should look like this.
  13. HP ENVY 5530 Paper Tray Replacement: paso 13, imagen 1 de 3 HP ENVY 5530 Paper Tray Replacement: paso 13, imagen 2 de 3 HP ENVY 5530 Paper Tray Replacement: paso 13, imagen 3 de 3
    • Remove paper tray by pulling it out and away from the printer.
    • Be cautious of jumping springs once pulling out the paper tray.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 4-6, Meier Fall 2015 Miembro de USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 27
Todo El Tiempo: 2,331
