Saltar al contenido principal
HP ENVY 5530 Paper Path Cover Replacement
  1. HP ENVY 5530 Paper Path Cover Replacement, Paper Path Cover: paso 1, imagen 1 de 1
    • Locate the paper cover.
  2. HP ENVY 5530 Paper Path Cover Replacement: paso 2, imagen 1 de 3 HP ENVY 5530 Paper Path Cover Replacement: paso 2, imagen 2 de 3 HP ENVY 5530 Paper Path Cover Replacement: paso 2, imagen 3 de 3
    • Push the two grey connectors together
    • Lift up to remove paper path cover.
Conclusión
Equipo
USF Tampa, Team 4-6, Meier Fall 2015 Miembro de USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Miembros
18 Guías creadas
2 comentarios
The problem, though, is in the precise alignment of the cover when squeezing the connectors. If not done
precisely, the cover will not seat properly and printing cannot be resumed.
marylandcatdad - Contestar
do you know where i could buy just the paper path cover?
Qamar Mohamoud - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 1,986
