Saltar al contenido principal
HP ENVY 5530 Gear for Scanner Arm Replacement
Qué necesitas
  1. HP ENVY 5530 Gear for Scanner Arm Replacement, Gear for Scanner Arm Actuator: paso 1, imagen 1 de 3 HP ENVY 5530 Gear for Scanner Arm Replacement, Gear for Scanner Arm Actuator: paso 1, imagen 2 de 3 HP ENVY 5530 Gear for Scanner Arm Replacement, Gear for Scanner Arm Actuator: paso 1, imagen 3 de 3
    • Unscrew and remove the center 13mm T10 Torx Security screw using the iFixit screwdriver
    • Unscrew and remove the top right 13mm T10 Torx Security screw using the iFixit screwdriver
    • Unscrew and remove the bottom left 13mm T10 Torx Security screw using the iFixit screwdriver
  2. HP ENVY 5530 Gear for Scanner Arm Replacement: paso 2, imagen 1 de 3 HP ENVY 5530 Gear for Scanner Arm Replacement: paso 2, imagen 2 de 3 HP ENVY 5530 Gear for Scanner Arm Replacement: paso 2, imagen 3 de 3
    • Unscrew and remove the bottom 13mm TR10 Torx Security screws using the iFixit screwdriver
  3. HP ENVY 5530 Gear for Scanner Arm Replacement: paso 3, imagen 1 de 3 HP ENVY 5530 Gear for Scanner Arm Replacement: paso 3, imagen 2 de 3 HP ENVY 5530 Gear for Scanner Arm Replacement: paso 3, imagen 3 de 3
    • Unscrew and remove the top right13mm TR10 Torx Security screws using the iFixit screwdriver
  4. HP ENVY 5530 Gear for Scanner Arm Replacement: paso 4, imagen 1 de 2 HP ENVY 5530 Gear for Scanner Arm Replacement: paso 4, imagen 2 de 2
    • Unscrew and remove the upper 13mm TR10 Torx Security screw using the iFixit screwdriver
  5. HP ENVY 5530 Gear for Scanner Arm Replacement: paso 5, imagen 1 de 2 HP ENVY 5530 Gear for Scanner Arm Replacement: paso 5, imagen 2 de 2
    • Remove the scanner lid and plate (top cover).
    • Locate the Scanner Arm Actuator.
  6. HP ENVY 5530 Gear for Scanner Arm Replacement: paso 6, imagen 1 de 2 HP ENVY 5530 Gear for Scanner Arm Replacement: paso 6, imagen 2 de 2
    • Locate the Scanner Arm Accuator and remove.
  7. HP ENVY 5530 Gear for Scanner Arm Replacement: paso 7, imagen 1 de 2 HP ENVY 5530 Gear for Scanner Arm Replacement: paso 7, imagen 2 de 2
    • Unscrew and remove the 13mm TR10 Torx Security screw in the center of the gear using the iFixit screwdriver
  8. HP ENVY 5530 Gear for Scanner Arm Replacement: paso 8, imagen 1 de 3 HP ENVY 5530 Gear for Scanner Arm Replacement: paso 8, imagen 2 de 3 HP ENVY 5530 Gear for Scanner Arm Replacement: paso 8, imagen 3 de 3
    • Locate the white gear and remove.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 4-6, Meier Fall 2015 Miembro de USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Miembros
18 Guías creadas
3 comentarios
It is not possible to get to the bottom two screws out without tilting the scan bed/cover back more. To that, I had to disconnect the swing arm on the right side of the scanner bed/cover. After that, all worked smoothly. Thank you.
Ron - Contestar
I have this model too and the scanner quits scanning - usually in mis-scan. I then have to cancel and shut down the machine. Lifting an end of the machine and dropping it (that's right) usually brings the scanning operation back to life once power is restored. I'm curious - what were the symptoms the author of the guide ran into? Why the gear? Why not the electronics? Where can one get the gear?
Joel Bacon - Contestar
bonjour
je cherche a me procurer pour le scanner de l imprimante HP Envy 5530 la piece engrenage blanc a remplacer dans le bras du scanner
jean pierre le philippe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 23
Todo El Tiempo: 1,884
