Saltar al contenido principal
HP Deskjet GT-5821 Scanner Glass Replacement
Qué necesitas
  1. HP Deskjet GT-5821 Scanner Glass Replacement, Open front access panel: paso 1, imagen 1 de 1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet GT-5821 Scanner Glass Replacement, Top Lid: paso 2, imagen 1 de 1
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. HP Deskjet GT-5821 Scanner Glass Replacement: paso 3, imagen 1 de 3 HP Deskjet GT-5821 Scanner Glass Replacement: paso 3, imagen 2 de 3 HP Deskjet GT-5821 Scanner Glass Replacement: paso 3, imagen 3 de 3
    • Remove the four 9mm T10 Torx screws on the top.
  4. HP Deskjet GT-5821 Scanner Glass Replacement: paso 4, imagen 1 de 2 HP Deskjet GT-5821 Scanner Glass Replacement: paso 4, imagen 2 de 2
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. HP Deskjet GT-5821 Scanner Glass Replacement: paso 5, imagen 1 de 3 HP Deskjet GT-5821 Scanner Glass Replacement: paso 5, imagen 2 de 3 HP Deskjet GT-5821 Scanner Glass Replacement: paso 5, imagen 3 de 3
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
  6. HP Deskjet GT-5821 Scanner Glass Replacement, Remove Back Panel of Lid: paso 6, imagen 1 de 1
    • Remove one 9mm T10 Torx screw from the back of the printer lid.
  7. HP Deskjet GT-5821 Scanner Glass Replacement: paso 7, imagen 1 de 2 HP Deskjet GT-5821 Scanner Glass Replacement: paso 7, imagen 2 de 2
    • Press outward on the plastic tab holding the back panel in place.
  8. HP Deskjet GT-5821 Scanner Glass Replacement: paso 8, imagen 1 de 2 HP Deskjet GT-5821 Scanner Glass Replacement: paso 8, imagen 2 de 2
    • Pull the back panel towards you and lift it away from the rest of the printer cover.
    • Some ribbon cables may still be inserted through the back panel. Be careful not to damage these and they should slide out easily.
  9. HP Deskjet GT-5821 Scanner Glass Replacement, Scanner Glass: paso 9, imagen 1 de 1
    • Remove one 9mm T10 Torx screw from the white retaining tab.
  10. HP Deskjet GT-5821 Scanner Glass Replacement: paso 10, imagen 1 de 1
    • Remove the white retaining tab.
  11. HP Deskjet GT-5821 Scanner Glass Replacement: paso 11, imagen 1 de 1
    • To remove the scanner glass, gently push it towards you.
    • Slide glass panel until it is completely removed from printer.
    • Use caution when removing glass and be aware of any sharp edges.
Conclusión
3 personas más completaron esta guía.
Kevin Raives
Miembro Desde 01/15/13
93 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 18-35, Regan Winter 2013 Miembro de Cal Poly, Team 18-35, Regan Winter 2013
CPSU-REGAN-W13S18G35
5 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 2,114
