Introducción
If the scans or copies made are not matching the desired document, replacing the scanner glass is a solution to consider. There could be a crack or scratch in the glass affecting the quality of the scanned or copied document.
Partes
No se requieren partes.
  1. Open the front access panel by placing your finger in the front slot and pulling gently.
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top.
    • Remove the four 9mm T10 Torx screws on the top.
  4. Carefully lift the top panel off of the printer. Do not tear or damage the two cables that connect the top lid to the motherboard.
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
  7. Remove one 9mm T10 Torx screw from the back of the printer lid.
    • Remove one 9mm T10 Torx screw from the back of the printer lid.
  8. Press outward on the plastic tab holding the back panel in place. Press outward on the plastic tab holding the back panel in place.
    • Press outward on the plastic tab holding the back panel in place.
  9. Pull the back panel towards you and lift it away from the rest of the printer cover. Some ribbon cables may still be inserted through the back panel. Be careful not to damage these and they should slide out easily.
    • Pull the back panel towards you and lift it away from the rest of the printer cover.
    • Some ribbon cables may still be inserted through the back panel. Be careful not to damage these and they should slide out easily.
  10. Remove one 9mm T10 Torx screw from the white retaining tab.
    • Remove one 9mm T10 Torx screw from the white retaining tab.
  11. Remove the white retaining tab.
    • Remove the white retaining tab.
  12. To remove the scanner glass, gently push it towards you.
    • To remove the scanner glass, gently push it towards you.
    • Slide glass panel until it is completely removed from printer.
    • Use caution when removing glass and be aware of any sharp edges.
Conclusión
3 personas más completaron esta guía.
Kevin Raives
Miembro Desde 15/01/13
87 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 18-35, Regan Winter 2013 Miembro de Cal Poly, Team 18-35, Regan Winter 2013
CPSU-REGAN-W13S18G35
5 Miembros
8 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 15
Todo El Tiempo: 1,321
