Saltar al contenido principal
HP Deskjet D1660 Power Button Replacement
Qué necesitas
  1. HP Deskjet D1660 Power Button Replacement, Top Cover: paso 1, imagen 1 de 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Power Button Replacement: paso 2, imagen 1 de 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Power Button Replacement: paso 3, imagen 1 de 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Power Button Replacement: paso 4, imagen 1 de 3 HP Deskjet D1660 Power Button Replacement: paso 4, imagen 2 de 3 HP Deskjet D1660 Power Button Replacement: paso 4, imagen 3 de 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Power Button Replacement, Power Button: paso 5, imagen 1 de 1
    • Remove the strip that connects the printer to the front cover.
  6. HP Deskjet D1660 Power Button Replacement: paso 6, imagen 1 de 2 HP Deskjet D1660 Power Button Replacement: paso 6, imagen 2 de 2
    • Remove the two 13.0 mm Torx #10 screws.
    • Carefully lift it up. The button will be located under it.
  7. HP Deskjet D1660 Power Button Replacement: paso 7, imagen 1 de 1
    • Lift up the power button.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 1-41, Maness Winter 2014 Miembro de Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 984
