Saltar al contenido principal
HP Deskjet D1660 Encoder Strip Replacement
Qué necesitas
  1. HP Deskjet D1660 Encoder Strip Replacement, Encoder Strip: paso 1, imagen 1 de 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Encoder Strip Replacement: paso 2, imagen 1 de 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Encoder Strip Replacement: paso 3, imagen 1 de 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Encoder Strip Replacement: paso 4, imagen 1 de 3 HP Deskjet D1660 Encoder Strip Replacement: paso 4, imagen 2 de 3 HP Deskjet D1660 Encoder Strip Replacement: paso 4, imagen 3 de 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Encoder Strip Replacement: paso 5, imagen 1 de 3 HP Deskjet D1660 Encoder Strip Replacement: paso 5, imagen 2 de 3 HP Deskjet D1660 Encoder Strip Replacement: paso 5, imagen 3 de 3
    • Looking at the printer from the front, carefully unhook the encoder strip from the left side.
    • Pull the strip to the left and push a little to unhook the strip.
    • Do the same thing on the other side by pulling to the right and pushing a little.
    • Pull the strip completely out from the cartridge holder.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 1-41, Maness Winter 2014 Miembro de Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 28
Todo El Tiempo: 4,337
