Saltar al contenido principal
HP Deskjet 3522 Ink Cartridge Replacement
  1. HP Deskjet 3522 Ink Cartridge Replacement, Ink Cartridge: paso 1, imagen 1 de 2 HP Deskjet 3522 Ink Cartridge Replacement, Ink Cartridge: paso 1, imagen 2 de 2
    • Power printer on.
    • Lift up the lid to the printer using the notch on the right side of the printer to expose the ink cartridges.
  2. HP Deskjet 3522 Ink Cartridge Replacement: paso 2, imagen 1 de 2 HP Deskjet 3522 Ink Cartridge Replacement: paso 2, imagen 2 de 2
    • Press down gently on the front tab of the ink cartridge that needs replacing and then lift up.
  3. HP Deskjet 3522 Ink Cartridge Replacement: paso 3, imagen 1 de 1
    • Make sure you have the correct model number of ink that needs to be replaced.
    • For the HP Deskjet 3522 the required ink is HP 564 (Regular or XL)
  4. HP Deskjet 3522 Ink Cartridge Replacement: paso 4, imagen 1 de 2 HP Deskjet 3522 Ink Cartridge Replacement: paso 4, imagen 2 de 2
    • Angle the new ink cartridge to the back and slide it into the slot. Press down gently on the head until you hear a soft click.
    • Close the lid and allow the printer to recalibrate itself.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-30, Donnelly Fall 2014 Miembro de USF Tampa, Team 1-30, Donnelly Fall 2014
USFT-DONNELLY-F14S1G30
1 Miembro
2 Guías creadas
Un comentario
These instructions were perfect to follow and complete.
walterawa1862 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 2,482
