Saltar al contenido principal
HP Deskjet 2624 Scanner Glass Replacement
Qué necesitas
  1. HP Deskjet 2624 Scanner Glass Replacement, Scanner Glass: paso 1, imagen 1 de 1
    • Unplug all cords from the printer, and remove all the paper from the tray.
  2. HP Deskjet 2624 Scanner Glass Replacement: paso 2, imagen 1 de 2 HP Deskjet 2624 Scanner Glass Replacement: paso 2, imagen 2 de 2
    • Remove the four screws securing the scanner bed module to the printer body with a Torx T5 screwdriver.
  3. HP Deskjet 2624 Scanner Glass Replacement: paso 3, imagen 1 de 1
    • Gently pry the scanner bed cover slightly off of the printer at the hinge.
    • Lifting the scanning bed cover to a 45 degree angle may make it easier to remove.
  4. HP Deskjet 2624 Scanner Glass Replacement: paso 4, imagen 1 de 1
    • Lift up the scanner bed module and remove the two ribbon cables by pulling them straight out.
    • Set the printer body aside.
  5. HP Deskjet 2624 Scanner Glass Replacement: paso 5, imagen 1 de 3 HP Deskjet 2624 Scanner Glass Replacement: paso 5, imagen 2 de 3 HP Deskjet 2624 Scanner Glass Replacement: paso 5, imagen 3 de 3
    • Separate the plastic halves of the scanner bed by gently pulling the tabs on the clips holding the halves together.
    • Pull the halves apart while undoing the clips to prevent plastic snapping.
  6. HP Deskjet 2624 Scanner Glass Replacement: paso 6, imagen 1 de 2 HP Deskjet 2624 Scanner Glass Replacement: paso 6, imagen 2 de 2
    • Remove the glass pane from the plastic shell by prying the tabs back that secure the glass, as well as peeling the adhesive apart slowly.
    • Glass edges can be sharp, handle glass and glass shards with gloves.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 36
Todo El Tiempo: 735
