Saltar al contenido principal
HP Deskjet 2624 Motherboard Replacement
Qué necesitas
  1. HP Deskjet 2624 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Unplug all cords from the printer and remove the paper.
  2. HP Deskjet 2624 Motherboard Replacement: paso 2, imagen 1 de 2 HP Deskjet 2624 Motherboard Replacement: paso 2, imagen 2 de 2
    • Using the Torx T5 screwdriver, remove the four screws connecting the scanner bed module to the printer base.
  3. HP Deskjet 2624 Motherboard Replacement: paso 3, imagen 1 de 2 HP Deskjet 2624 Motherboard Replacement: paso 3, imagen 2 de 2
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the cables connected to the motherboard by gently pulling them straight out. Do not unplug the cables by pulling on the wires.
    • Unplug the last two ribbons connected to the motherboard by gently pulling them straight out.
    • Be sure to take note of where all plugs and ribbons are connected to the motherboard.
    • Remove the motherboard from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 545
