Saltar al contenido principal
HP Deskjet 2624 Ink Cartridges Replacement
  1. HP Deskjet 2624 Ink Cartridges Replacement, Ink Cartridges: paso 1, imagen 1 de 1
    • Unplug all of the cords from the printer and put paper into the input tray.
  2. HP Deskjet 2624 Ink Cartridges Replacement: paso 2, imagen 1 de 3 HP Deskjet 2624 Ink Cartridges Replacement: paso 2, imagen 2 de 3 HP Deskjet 2624 Ink Cartridges Replacement: paso 2, imagen 3 de 3
    • Lower the output tray and the ink cartridge access door.
    • Lightly press forward on the cartridge to release it and then pull the cartridge straight out.
    • The slot on the left is the tri-color cartridge while the black cartridge is on the right.
  3. HP Deskjet 2624 Ink Cartridges Replacement: paso 3, imagen 1 de 3 HP Deskjet 2624 Ink Cartridges Replacement: paso 3, imagen 2 de 3 HP Deskjet 2624 Ink Cartridges Replacement: paso 3, imagen 3 de 3
    • On the new cartridge, pull the colored tab to remove the plastic.
    • Hold the replacement with the nozzles toward the printer and insert it at an upward angle.
    • Push the cartridge forward until it snaps into place.
    • Repeat steps two and three if necessary.
Conclusión
After completing this guide, don’t forget to plug in your HP Deskjet 2624 .
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 25
Todo El Tiempo: 1,160
