Saltar al contenido principal
HP Deskjet 1055 Ink Cartridge Replacement
Qué necesitas
  1. HP Deskjet 1055 Ink Cartridge Replacement, Ink Cartridge: paso 1, imagen 1 de 1
    • Turn on the printer by pressing the power button.
  2. HP Deskjet 1055 Ink Cartridge Replacement: paso 2, imagen 1 de 2 HP Deskjet 1055 Ink Cartridge Replacement: paso 2, imagen 2 de 2
    • Place your index finger in the opening on the front of the printer (right side below scanner/copier) and pull the door down.
    • Pull down on the tab that lies in the middle of the newly-exposed gray cover.
  3. HP Deskjet 1055 Ink Cartridge Replacement: paso 3, imagen 1 de 1
    • The tri-color cartridge sits on the left side; the black cartridge sits on the right.
    • Grab the cartridge from the top and bottom and pull down until it clicks.
    • Pull out the freed cartridge.
  4. HP Deskjet 1055 Ink Cartridge Replacement: paso 4, imagen 1 de 3 HP Deskjet 1055 Ink Cartridge Replacement: paso 4, imagen 2 de 3 HP Deskjet 1055 Ink Cartridge Replacement: paso 4, imagen 3 de 3
    • Take the replacement cartridge out of its packaging and pull off the plastic tab.
    • Do not touch the electrical contacts or ink nozzles. Touching may cause malfunctions.
    • Hold the cartridge on both sides with the title sticker facing upwards.
  5. HP Deskjet 1055 Ink Cartridge Replacement: paso 5, imagen 1 de 2 HP Deskjet 1055 Ink Cartridge Replacement: paso 5, imagen 2 de 2
    • Slide the cartridge directly into open slot (tri-color on the left, black on the right).
    • Push it forward until you hear it snap.
  6. HP Deskjet 1055 Ink Cartridge Replacement: paso 6, imagen 1 de 1
    • Close the gray access door.
  7. HP Deskjet 1055 Ink Cartridge Replacement: paso 7, imagen 1 de 2 HP Deskjet 1055 Ink Cartridge Replacement: paso 7, imagen 2 de 2
    • Wait 30 seconds for the alignment page to print.
    • Open up the scanner lid and place the alignment page face-down in the right-front corner of the glass.
    • Close the lid.
  8. HP Deskjet 1055 Ink Cartridge Replacement: paso 8, imagen 1 de 1
    • Press the color copy button to begin scan.
    • Wait until the power button stops blinking.
Conclusión
When the power button stops blinking, your can now use your printer.
4 personas más completaron esta guía.
Daniel
Miembro Desde 10/06/12
314 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-18, Amido Fall 2012 Miembro de Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 15,990
