Introducción
The plug ports are soldered onto the circuit board, so this is more of a circuit board replacement. Be careful when handling electronic circuit boards to avoid damaging the components and to avoid electric shock.
Qué necesitas
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
Herramienta utilizada en este paso:Tweezers$4.99
Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
Una persona más ha completado esta guía.
