Introducción
The ink carriage motor is responsible for moving the ink cartridge around for it to disperse ink. Follow these steps carefully and it should be an easy fix.
Qué necesitas
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
Remove the two 13mm screws with the screwdriver and a T10 torx bit.
Remove the one 9mm screw with the screwdriver and a T10 torx bit.
2 personas más completaron esta guía.
