Saltar al contenido principal
HP Compaq nc8430 Battery Replacement
  1. HP Compaq nc8430 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
  2. HP Compaq nc8430 Battery Replacement: paso 2, imagen 1 de 1
    • Slide up against the three lines the battery has.
  3. HP Compaq nc8430 Battery Replacement: paso 3, imagen 1 de 1
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
Conclusión
Karen Gandara
Miembro Desde 03/20/17
101 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 6
Todo El Tiempo: 738
