Saltar al contenido principal
HP Compaq Presario V6000 Cooling Fan Replacement
Qué necesitas
    • Remove all of circled screws.
    • Be careful not to lose or misplace any screws. We suggest using a magnet board to keep everything together.
  1. HP Compaq Presario V6000 Cooling Fan Replacement: paso 2, imagen 1 de 1
    • After removing the backs of the memory card and hard drive cover, gently remove the silver screen.
  2. HP Compaq Presario V6000 Cooling Fan Replacement: paso 3, imagen 1 de 1
    • After removing the back of the memory card and the back of the hard drive, remove the CD Drive by gently pulling it all the way out of the device.
  3. HP Compaq Presario V6000 Cooling Fan Replacement: paso 4, imagen 1 de 2 HP Compaq Presario V6000 Cooling Fan Replacement: paso 4, imagen 2 de 2
    • After all components are removed, use your hands to separate the base plate form the main housing. If your fingers can not separate the 2 pieces; insert the metal spudger to create space.
  4. HP Compaq Presario V6000 Cooling Fan Replacement: paso 5, imagen 1 de 1
    • Remove all screw we have designated in the photo.
  5. HP Compaq Presario V6000 Cooling Fan Replacement: paso 6, imagen 1 de 1
    • After all screws are removed use metal spudger to pry the plastic housing away from the ports to separate.
    • Use light pressure when separating the plastic housing
  6. HP Compaq Presario V6000 Cooling Fan Replacement: paso 7, imagen 1 de 1
    • Separate the motherboard from the rest of the components.
  7. HP Compaq Presario V6000 Cooling Fan Replacement: paso 8, imagen 1 de 2 HP Compaq Presario V6000 Cooling Fan Replacement: paso 8, imagen 2 de 2
    • Remove designated screws
    • Unplug the ribbon connecting the cooling fan to the motherboard.
    • After unplugging and unscrewing you will be able to detach cooling fan
Conclusión
2 personas más completaron esta guía.
adam
Miembro Desde 10/11/16
323 Reputación
2 Guías creadas
Equipo
Texas Tech, Team 38-4, Bennett Fall 2016 Miembro de Texas Tech, Team 38-4, Bennett Fall 2016
TTU-BENNETT-F16S38G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 983
