Saltar al contenido principal
HP Compaq Presario V5303NR Keyboard Replacement
Qué necesitas
  1. HP Compaq Presario V5303NR Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 HP Compaq Presario V5303NR Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 HP Compaq Presario V5303NR Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Turn laptop bottom-side up.
    • Push the battery latch to the left position to unlock the battery.
    • Lift the battery out of its socket.
    • Failure to unplug the computer and remove the battery can result in electrical discharges on contact with the computer's components. This can damage the computer or even hurt the user.
  2. HP Compaq Presario V5303NR Keyboard Replacement: paso 2, imagen 1 de 2 HP Compaq Presario V5303NR Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove the 5 mm and 4 mm screws shown, represented in red and orange, respectively, using a Phillips #0 Screwdriver.
    • Keep all different types of screw separate from one another; they are different sizes, and cannot fit into the other's spaces upon reassembly.
  3. HP Compaq Presario V5303NR Keyboard Replacement: paso 3, imagen 1 de 1
    • Turn the laptop right-side up.
    • Carefully open the laptop as far as it can.
  4. HP Compaq Presario V5303NR Keyboard Replacement: paso 4, imagen 1 de 2 HP Compaq Presario V5303NR Keyboard Replacement: paso 4, imagen 2 de 2
    • Insert the metal spudger in the space between the switch cover and the F1, F5, F11 and Insert keys.
    • Use the spudger to carefully pry the cover plate away from the keyboard and laptop at the aforementioned locations. Remove the cover plate.
    • If it is possible to do so, it is advised to use a plastic spudger instead of a metal one. The metal spudger can damage the computer's internal components, but the plastic one may be too thick to fit in the gap.
  5. HP Compaq Presario V5303NR Keyboard Replacement: paso 5, imagen 1 de 3 HP Compaq Presario V5303NR Keyboard Replacement: paso 5, imagen 2 de 3 HP Compaq Presario V5303NR Keyboard Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #0 Screwdriver to remove the 4 4mm screws shown in the second picture. As per before, keep them separated from the screws removed in step 2.
    • Carefully lift up the section of the keyboard closest to the screen. Slowly rotate it downwards until it is resting on top of the touch pad.
  6. HP Compaq Presario V5303NR Keyboard Replacement: paso 6, imagen 1 de 2 HP Compaq Presario V5303NR Keyboard Replacement: paso 6, imagen 2 de 2
    • Using your fingers, carefully pull the ribbon cable connecting the keyboard and laptop toward the hinge. Continue until connecting cable is unplugged.
    • Remove keyboard from laptop.
Conclusión
Una persona más ha completado esta guía.
Chris Obesky
Miembro Desde 03/16/18
617 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 161
