Saltar al contenido principal
HP Compaq Presario V5303NR Battery Replacement
  1. HP Compaq Presario V5303NR Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Compaq Presario V5303NR Battery Replacement, Battery: paso 1, imagen 2 de 2
    • A switch is located below the battery, take your finger and push it over to the left.
    • The instruction to push the latch to the left is only relevant to the first image. The second image, which was included to provide a clearer image of said latch, would have the latch pushed to the right.
    • After this the battery should pop up and be dislodged
  2. HP Compaq Presario V5303NR Battery Replacement: paso 2, imagen 1 de 1
    • Remove the battery from its socket.
Conclusión
Ryan Dunn
Miembro Desde 03/18/18
197 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 141
