Saltar al contenido principal
HP Compaq Presario CQ56-110US Keyboard Replacement
Qué necesitas
Resumen del Video
  1. HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: paso 1, imagen 1 de 2 HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure that the laptop is completely powered off, then flip it over to identify the battery latch located towards the bottom of the back panel.
    • Push the latch to the unlocked position.
  2. HP Compaq Presario CQ56-110US Keyboard Replacement: paso 2, imagen 1 de 1
    • Gently take out the battery.
  3. HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: paso 3, imagen 1 de 2 HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: paso 3, imagen 2 de 2
    • On the back panel of the laptop are two screws which have a keyboard symbol next to them.
    • Using a Phillips screwdriver with a PH0 bit, remove both the 7mm and 5.5mm screws.
  4. HP Compaq Presario CQ56-110US Keyboard Replacement: paso 4, imagen 1 de 2 HP Compaq Presario CQ56-110US Keyboard Replacement: paso 4, imagen 2 de 2
    • From left to right, unscrew the 5.5mm screw, the 7mm screw, and the 5.5mm screw located in the battery panel with the screwdriver.
  5. HP Compaq Presario CQ56-110US Keyboard Replacement: paso 5, imagen 1 de 2 HP Compaq Presario CQ56-110US Keyboard Replacement: paso 5, imagen 2 de 2
    • Remove the RAM panel by unscrewing the three screws with the PH0 Screwdriver Bit.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool
    • Remove the RAM panel using a plastic opening tool.
  6. HP Compaq Presario CQ56-110US Keyboard Replacement: paso 6, imagen 1 de 1
    • Inside the RAM panel, use the screwdriver to remove the 5mm screw pictured.
  7. HP Compaq Presario CQ56-110US Keyboard Replacement: paso 7, imagen 1 de 1
    • Flip the laptop back over and lift the lid to expose the keyboard.
  8. HP Compaq Presario CQ56-110US Keyboard Replacement: paso 8, imagen 1 de 2 HP Compaq Presario CQ56-110US Keyboard Replacement: paso 8, imagen 2 de 2
    • Use a plastic opening tool to pry up the keyboard.
  9. HP Compaq Presario CQ56-110US Keyboard Replacement: paso 9, imagen 1 de 2 HP Compaq Presario CQ56-110US Keyboard Replacement: paso 9, imagen 2 de 2
    • Once the keyboard is lifted, disconnect the band.
Conclusión
3 personas más completaron esta guía.
Iyonna L. Tynes
Miembro Desde 02/15/17
446 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 8-4, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-4, Eyestone Spring 2017
USFT-EYESTONE-S17S8G4
4 Miembros
5 Guías creadas
Un comentario
Difficulty HARD ? oh please… please change to EASY… just some screws?
Assembler Computer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 3,513
