Saltar al contenido principal
HP Compaq NC6120 Monitor Replacement
Qué necesitas
  1. HP Compaq NC6120 Monitor Replacement, Monitor: paso 1, imagen 1 de 2 HP Compaq NC6120 Monitor Replacement, Monitor: paso 1, imagen 2 de 2
    • Locate and remove four black 5.1mm Phillips #1 screws from the left and right sides of the monitor.
  2. HP Compaq NC6120 Monitor Replacement: paso 2, imagen 1 de 3 HP Compaq NC6120 Monitor Replacement: paso 2, imagen 2 de 3 HP Compaq NC6120 Monitor Replacement: paso 2, imagen 3 de 3
    • Using a small spudger, remove the four black plastic covers from above the monitor, revealing screws underneath.
  3. HP Compaq NC6120 Monitor Replacement: paso 3, imagen 1 de 1
    • Remove the four screws that were just uncovered. They are 6.2mm 3.0 flathead screws.
  4. HP Compaq NC6120 Monitor Replacement: paso 4, imagen 1 de 1
    • Pry off the plastic case surrounding the monitor.
    • A spudger may be needed to pry off the case.
  5. HP Compaq NC6120 Monitor Replacement: paso 5, imagen 1 de 3 HP Compaq NC6120 Monitor Replacement: paso 5, imagen 2 de 3 HP Compaq NC6120 Monitor Replacement: paso 5, imagen 3 de 3
    • Remove the black and silver cable, located directly below the monitor.
    • Proceed to pull monitor approximately 10cm away from the back of the laptop case.
  6. HP Compaq NC6120 Monitor Replacement: paso 6, imagen 1 de 2 HP Compaq NC6120 Monitor Replacement: paso 6, imagen 2 de 2
    • Remove the grey cable (with yellow tip) connecting the monitor to the back plastic casing and the monitor will be free from the rest of the laptop.
Conclusión
Una persona más ha completado esta guía.
Mateo Cuellar
Miembro Desde 04/08/15
601 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 17-4, Forte Spring 2015 Miembro de Cal Poly, Team 17-4, Forte Spring 2015
CPSU-FORTE-S15S17G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 1,506
