Saltar al contenido principal
HP Compaq C700 Touchpad Replacement
Qué necesitas
  1. HP Compaq C700 Touchpad Replacement, Keyboard: paso 1, imagen 1 de 1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Touchpad Replacement: paso 2, imagen 1 de 3 HP Compaq C700 Touchpad Replacement: paso 2, imagen 2 de 3 HP Compaq C700 Touchpad Replacement: paso 2, imagen 3 de 3
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Touchpad Replacement: paso 3, imagen 1 de 1
    • Gently lift up and remove the keyboard.
  4. HP Compaq C700 Touchpad Replacement, Touchpad: paso 4, imagen 1 de 1
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
  5. HP Compaq C700 Touchpad Replacement: paso 5, imagen 1 de 1
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
  6. HP Compaq C700 Touchpad Replacement: paso 6, imagen 1 de 1
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
  7. HP Compaq C700 Touchpad Replacement: paso 7, imagen 1 de 1
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
  8. HP Compaq C700 Touchpad Replacement: paso 8, imagen 1 de 1
    • Gently lift and pull out the card.
  9. HP Compaq C700 Touchpad Replacement: paso 9, imagen 1 de 1
    • Locate the power button connector wire.
    • Using the tweezers, unhook the wire.
  10. HP Compaq C700 Touchpad Replacement: paso 10, imagen 1 de 2 HP Compaq C700 Touchpad Replacement: paso 10, imagen 2 de 2
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
  11. HP Compaq C700 Touchpad Replacement: paso 11, imagen 1 de 3 HP Compaq C700 Touchpad Replacement: paso 11, imagen 2 de 3 HP Compaq C700 Touchpad Replacement: paso 11, imagen 3 de 3
    • Unplug the remaining wires using the tweezers.
  12. HP Compaq C700 Touchpad Replacement: paso 12, imagen 1 de 1
    • Gently pull out the three wires.
  13. HP Compaq C700 Touchpad Replacement: paso 13, imagen 1 de 2 HP Compaq C700 Touchpad Replacement: paso 13, imagen 2 de 2
    • Locate the four 3 mm Phillips head screws.
  14. HP Compaq C700 Touchpad Replacement: paso 14, imagen 1 de 1
    • Unhook the display connector wire.
  15. HP Compaq C700 Touchpad Replacement: paso 15, imagen 1 de 1
    • Gently disconnect the display by pulling it upwards.
  16. HP Compaq C700 Touchpad Replacement: paso 16, imagen 1 de 1
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
  17. HP Compaq C700 Touchpad Replacement: paso 17, imagen 1 de 1
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
  18. HP Compaq C700 Touchpad Replacement: paso 18, imagen 1 de 1
    • Disconnect the touchpad connection using the tweezers.
  19. HP Compaq C700 Touchpad Replacement: paso 19, imagen 1 de 1
    • Use the plastic opening tool to pry up all sides of the device cover.
  20. HP Compaq C700 Touchpad Replacement: paso 20, imagen 1 de 1
    • Remove the cover by lifting it.
  21. HP Compaq C700 Touchpad Replacement: paso 21, imagen 1 de 1
    • Use the PH0 screwdriver to remove the six 1 mm Phillips head screws surrounding the touchpad
  22. HP Compaq C700 Touchpad Replacement: paso 22, imagen 1 de 1
    • Use the tweezers to remove the touchpad wire connection.
  23. HP Compaq C700 Touchpad Replacement: paso 23, imagen 1 de 2 HP Compaq C700 Touchpad Replacement: paso 23, imagen 2 de 2
    • Use the plastic opening tool to pry up the touchpad cover.
    • Lift and remove the touchpad cover.
  24. HP Compaq C700 Touchpad Replacement: paso 24, imagen 1 de 1
    • Use the blow dryer to melt the adhesive around the edge of the touchpad.
    • The touchpad is now free to be removed.
Conclusión
Una persona más ha completado esta guía.
Taylor Johansen
Miembro Desde 10/20/16
690 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 5-6, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Miembros
6 Guías creadas
Un comentario
I need Compaq laptop c700 Touch pad
So how can I get it?
Suraj Verma - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,340
