Saltar al contenido principal
HP Compaq C700 Keyboard Replacement
Qué necesitas
  1. HP Compaq C700 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Keyboard Replacement: paso 2, imagen 1 de 3 HP Compaq C700 Keyboard Replacement: paso 2, imagen 2 de 3 HP Compaq C700 Keyboard Replacement: paso 2, imagen 3 de 3
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Keyboard Replacement: paso 3, imagen 1 de 1
    • Gently lift up and remove the keyboard.
Conclusión
Una persona más ha completado esta guía.
Taylor Johansen
Miembro Desde 10/20/16
690 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 5-6, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Miembros
6 Guías creadas
2 comentarios
er zijn 3 schroeven aan het keyboard
marcel - Contestar
there is a third screw holding in the keyboard located under the RAM cover not mentioned in this guide, please make sure you remove that too or else you may end up warping your keyboard like my friend did with his C700.
Blackblur610 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 776
