Saltar al contenido principal
HP Compaq C700 Battery Replacement
  1. HP Compaq C700 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Battery Replacement: paso 2, imagen 1 de 1
    • On the underside of the laptop, locate the sliding lock that keeps the battery in place.
    • Using your finger, slide the battery lock to the left to unlock the battery. Once the battery is unlocked, it is free to be removed.
Conclusión
Una persona más ha completado esta guía.
Taylor Johansen
Miembro Desde 10/20/16
690 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 5-6, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Miembros
6 Guías creadas
Un comentario
thanks - appreciate this advice as I wasn’t able to get the battery out and thought I was missing something, but then I just tried harder!
Albert Einstein - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,241
