Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Compaq 6910p RAM Replacement
Qué necesitas
  1. HP Compaq 6910p RAM Replacement, RAM: paso 1, imagen 1 de 2 HP Compaq 6910p RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Loosen the 1.5 cm Phillips #1 screw.
    • Lift up the cover.
    Pregunta a FixBot
  2. HP Compaq 6910p RAM Replacement: paso 2, imagen 1 de 3 HP Compaq 6910p RAM Replacement: paso 2, imagen 2 de 3 HP Compaq 6910p RAM Replacement: paso 2, imagen 3 de 3
    • Locate the release latches marked in red.
    • Press down on the release latches simultaneously to release the RAM.
    • Remove the RAM.
    Pregunta a FixBot
Conclusión
2 personas más completaron esta guía.
Tyler Fricks
Miembro Desde 10/22/15
531 Reputación
5 Guías creadas
Equipo
Montana Tech, Team 3-2, Shirk Fall 2015 Miembro de Montana Tech, Team 3-2, Shirk Fall 2015
MTUM-SHIRK-F15S3G2
Miembros de 5
5 Guías creadas
5Guía Comentarios
Can The RAM in this machine run with anything more then just 2GB's? I am just wondering.
Marshall WahlstromHelgren - Contestar Compartir
This laptop can run even 8gb ram (2x4gb), the second slot is under the keyboard.
Zar' Roc - Contestar Compartir
How many gb of ram should be put in the back….a 4gb  or can an 8gb ram be inserted in the back so you can not have to put any more under the keyboard if you wanted to just upgrade to 8 gb at one time or 4gb at one time and not ever have to buy 2gb, 4gb or 8gb.  answer me at natefoster@bellsouth.net.  I have in my HP6910p  a 2gb ram and a small 60 harddrive and the computer seems to be slow.  Do I need to increase the ram or the harddrive  or both.  Help me with this.  I am waiting too long to start the computer up.  It is a good computer. What should I do to get more speed.
natefoster - Contestar Compartir
where´s the second slot located?
Patrick Wirth - Contestar Compartir
It is under the keyboard. There a few youtube videos showing how to remove the keyboard and get to the second slot.
Dynasty - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 79
Todo El Tiempo: 4,191
