Saltar al contenido principal
HP Compaq 6710b Wireless Card Replacement
Qué necesitas
  1. HP Compaq 6710b Wireless Card Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
  2. HP Compaq 6710b Wireless Card Replacement, Wireless Card: paso 2, imagen 1 de 2 HP Compaq 6710b Wireless Card Replacement, Wireless Card: paso 2, imagen 2 de 2
    • Make sure the computer is off.
    • Using a Phillips #1, unscrew the 5mm screw on the bottom of the laptop
    • Remove the back cover plate.
    • The cover has popping tabs so it might require a small amount of force to remove.
  3. HP Compaq 6710b Wireless Card Replacement: paso 3, imagen 1 de 2 HP Compaq 6710b Wireless Card Replacement: paso 3, imagen 2 de 2
    • Using a blue plastic prying tool, gently pry off the 2 connectors.
    • The black cable goes on the connection closer to where the cables originate, while the white cable goes on the farther connection.
  4. HP Compaq 6710b Wireless Card Replacement: paso 4, imagen 1 de 2 HP Compaq 6710b Wireless Card Replacement: paso 4, imagen 2 de 2
    • Using the Phillips #1 screwdriver, unscrew the 2 3mm screws.
    • Adaptor is spring-loaded.
    • You can now take out the adaptor.
Conclusión
2 personas más completaron esta guía.
Khulan Orgil
Miembro Desde 04/14/15
1,171 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 4-2, Maness Spring 2015 Miembro de Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 2,561
