Saltar al contenido principal
HP Compaq 6710b Power Button Panel Replacement
Qué necesitas
  1. HP Compaq 6710b Power Button Panel Replacement, Keyboard: paso 1, imagen 1 de 3 HP Compaq 6710b Power Button Panel Replacement, Keyboard: paso 1, imagen 2 de 3 HP Compaq 6710b Power Button Panel Replacement, Keyboard: paso 1, imagen 3 de 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Power Button Panel Replacement: paso 2, imagen 1 de 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Power Button Panel Replacement: paso 3, imagen 1 de 2 HP Compaq 6710b Power Button Panel Replacement: paso 3, imagen 2 de 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Power Button Panel Replacement: paso 4, imagen 1 de 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  5. HP Compaq 6710b Power Button Panel Replacement, Power Button Panel: paso 5, imagen 1 de 1
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
  6. HP Compaq 6710b Power Button Panel Replacement: paso 6, imagen 1 de 3 HP Compaq 6710b Power Button Panel Replacement: paso 6, imagen 2 de 3 HP Compaq 6710b Power Button Panel Replacement: paso 6, imagen 3 de 3
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
Conclusión
4 personas más completaron esta guía.
Khulan Orgil
Miembro Desde 04/14/15
1,171 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 4-2, Maness Spring 2015 Miembro de Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 3,389
