Saltar al contenido principal
HP Compaq 6710b Keyboard Replacement
Qué necesitas
  1. HP Compaq 6710b Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 HP Compaq 6710b Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 HP Compaq 6710b Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Keyboard Replacement: paso 2, imagen 1 de 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Keyboard Replacement: paso 3, imagen 1 de 2 HP Compaq 6710b Keyboard Replacement: paso 3, imagen 2 de 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Keyboard Replacement: paso 4, imagen 1 de 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
Conclusión
4 personas más completaron esta guía.
Khulan Orgil
Miembro Desde 04/14/15
1,171 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 4-2, Maness Spring 2015 Miembro de Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Miembros
6 Guías creadas
2 comentarios
No parts required to *replace* the keyboard?
David - Contestar
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
Victor Izquierdo Quesada - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 5,106
