Saltar al contenido principal
HP Compaq 6510b Hard Drive Replacement
Qué necesitas
  1. HP Compaq 6510b Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 HP Compaq 6510b Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b Hard Drive Replacement, Hard Drive: paso 2, imagen 1 de 3 HP Compaq 6510b Hard Drive Replacement, Hard Drive: paso 2, imagen 2 de 3 HP Compaq 6510b Hard Drive Replacement, Hard Drive: paso 2, imagen 3 de 3
    • Flip the laptop over and locate the sign that says HP 3D DriveGuard.
    • Remove the two 5mm JIS #1 screws with your screwdriver.
    • Carefully lift up the cover.
    • Carefully lift up the hard drive from the back and pull it out.
Conclusión
2 personas más completaron esta guía.
Joseph Noudom
Miembro Desde 03/01/18
569 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 887
